bradford
#1 Posted : 15 years ago
bradford
My heat pump is 2 years old. When the compressor tries to come on, it just grinds for a few seconds. Then it stops for a bit. Then tries again. Then stops. Then tries again. Etc. When it tries, the lits dim in the house a bit. The contactors are good. The capacitor APPEARS to be good. Sometimes the compressor will come on after a few tries. Sometimes it may be a few hours. Sometimes it never does come on. I know this should be under warranty, but getting someone out to fix it under warranty has proven difficult. Are there any steps anyone would recommend that I could try to troubleshooting it myself? I have read on the Web where the board in this model is actually a recall, but would that cause stuff like this? Any help that anyone could offer would be so greatly appreciated.
Thanks in advance.
hvac_hillbilly
#2 Posted : 15 years ago
hvac_hillbilly
try one of these sounds like your comprsser is locke or near locked this could be a tempory fix however probaly need to replace compressor 2 years old should be under warrenty but there may be a labor charge
Part Details - PRO HARD START KITS, part number: AP4502865
