3 Pages<123
angel fly
#21 Posted : Wednesday, March 3, 2010 4:14:48 AM(UTC)
angel fly
most importantly thank you for your patience the serial no. is rt164427 for whirlpool range with model no. sf362lxsb
#22 Posted : Wednesday, March 3, 2010 2:06:37 PM(UTC)
This replacement electronic board is a direct replacement for the gas range with the serial number you posted. That means you do not have to remove any wires.
angel fly
#23 Posted : Friday, March 5, 2010 4:31:57 AM(UTC)
angel fly
if the replacement board just can be changed did i read it wrong by replacing the wrong board? and thanks again for your support and expertise is there a chance i have to replace the gas/oven valve
#24 Posted : Friday, March 5, 2010 1:05:06 PM(UTC)
Before proceed with replacement of any parts you have to perform the troubleshooting and the gas valve/regulator is the first part which has to be tested. The procedure described in one of our previous threads: http://forum.appliancepartspros...l-oven-wont-heat-up.html
Guest (5)
Whirlpool gas stove bake not working (Oven Repair (including Ranges and Cooktops))
by Solomonsolomon 2/16/2021 7:46:53 PM(UTC)
Problem with my Whirlpool Gas Stove Model WFG525S0HT1 (Oven Repair (including Ranges and Cooktops))
by Airwolf1988 1/31/2021 3:54:22 PM(UTC)
whirlpool gas stove wrong error code (Oven Repair (including Ranges and Cooktops))
by colusapaul 12/6/2011 7:21:12 AM(UTC)
Whirlpool Gas Stove Acting weird (Oven Repair (including Ranges and Cooktops))
by colusapaul 12/3/2011 10:57:34 AM(UTC)
Whirlpool Gas Stove (Oven Repair (including Ranges and Cooktops))
by gdawgs 12/9/2010 10:23:05 AM(UTC)
Whirlpool Gas stove (Oven Repair (including Ranges and Cooktops))
by MissCindy 11/15/2010 6:11:51 AM(UTC)
Whirlpool Gas Stovetop (Oven Repair (including Ranges and Cooktops))
by VAS 8/9/2009 1:56:46 PM(UTC)
3 Pages<123
