most importantly thank you for your patience the serial no. is rt164427 for whirlpool range with model no. sf362lxsb
This replacement electronic board is a direct replacement for the gas range with the serial number you posted. That means you do not have to remove any wires.
if the replacement board just can be changed did i read it wrong by replacing the wrong board? and thanks again for your support and expertise is there a chance i have to replace the gas/oven valve
Originally Posted by: angel fly  if the replacement board just can be changed did i read it wrong by replacing the wrong board? and thanks again for your support and expertise is there a chance i have to replace the gas/oven valve Before proceed with replacement of any parts you have to perform the troubleshooting and the gas valve/regulator is the first part which has to be tested. The procedure described in one of our previous threads: http://forum.appliancepartspros...l-oven-wont-heat-up.htmlGene.
