dtassinari1
#1 Posted : Tuesday, February 16, 2010 6:34:41 AM(UTC)
dtassinari1
The washer runs, but sometimes in the middle of the cycle it gives an error on the display "sud" It will then sit for anywhere from 5 to 40 minutes before starting again. A couple of times the water didn't drain out when the cycle was complete.
magician59
#2 Posted : Tuesday, February 16, 2010 12:17:11 PM(UTC)
magician59
Try using less detergent, or one designed for the HE (High Efficiency) washers.
dtassinari1
#3 Posted : Wednesday, February 17, 2010 3:05:58 AM(UTC)
dtassinari1
Thank you for the suggestion. We have been using the same HE detergent for years. My wife ran out recently and ran some loads with normal detergent and it happened less. I know it seems odd. Any other suggestions?
#4 Posted : Wednesday, February 17, 2010 3:31:34 AM(UTC)
You might have soap residue that is foaming up. Dump a 1/2 gallon of vinegar in the tub and run a cycle, should clear it out.
dtassinari1
#5 Posted : Wednesday, March 3, 2010 3:53:46 AM(UTC)
dtassinari1
Thank you for the suggestion with the vinegar. I've tried a few times now with no success. I even tried dumping a full gallon and a half in the machine. I'm still getting the SUD error. Also, every so often, the machine won't drain the water at the end of the cycle. Any more suggestions?
#6 Posted : Wednesday, March 3, 2010 5:12:54 AM(UTC)
Your pump may be cavitating from stuff stuck in the tub hose. I would pull it apart and check.
SUD error followed by an F21 error (Washer Repair)
by Carlo P 7/28/2012 9:28:02 AM(UTC)
Sud error followed by F35 on a maytag 5000 series (Washer Repair)
by ED R 10/5/2010 8:11:31 PM(UTC)
Whirlpool Duet washer SUD error (Washer Repair)
by richappy 9/12/2010 12:42:30 AM(UTC)
