cabanaman_1999
#1 Posted : Saturday, April 5, 2008 7:36:50 PM(UTC)
cabanaman_1999
I have a Caloric Dish washer that is leaking water down the motor shaft. I have the motor out of the machine and half torn down. I need to get at the seal under the impeller but the impeller wont come off. the impeller is shaped like a nut on top, but I dont know if it unscrews or just slides up the shaft. I have tried both, but it wont move....is there something I'm doing wrong? Or is there a trick to the removal, I don't want to break it....as the unit is about 25 years old (but still works great). Thanks
cabanaman_1999
#2 Posted : Monday, April 7, 2008 3:36:21 PM(UTC)
cabanaman_1999
To the question I asked (for future reference).....The impeller slides on the shaft with a keyway. I found this out after breaking it off. It would not slide off, or unscrew. No part available so it's now scrap.
#3 Posted : Tuesday, April 8, 2008 1:17:53 PM(UTC)
According to the Appliance Parts Pros database the impeller and seal kit for your dishwasher is on back order but it is still available.
- The part number for the impeller and seal kit is AP146496
I would recommend to call the customer service.
Here are the break down diagrams for the Caloric dishwasher Model DUS204-19
#4 Posted : Wednesday, April 9, 2008 3:16:54 AM(UTC)
For future reference, I use a sharp wood chisel to bust the old impeller off.
cabanaman_1999
#5 Posted : Thursday, April 10, 2008 4:54:23 PM(UTC)
cabanaman_1999
Hi Gene.....Thanks for the reply....I had the breakdown, and the part number.....but, I didn't know how long it would be on backorder. It's for a rental house so I needed to act kind of quickly on the repair or replacement. After about 25 years I figured it was about time to replace it. Thanks though for the info! Dale
cabanaman_1999
#6 Posted : Thursday, April 10, 2008 5:02:22 PM(UTC)
cabanaman_1999
Hi Richappy, Yeah, A wood chisel would have worked real good. I found out a 1/2" socket and wratchet works real good also (ha ha). Not quite what I wanted to happen ,but I didn't know if it unscrewed or if it was on a keyway. But I know now. Thanks for the responce! Dale
Admin / APP Team
#7 Posted : Thursday, April 10, 2008 7:19:12 PM(UTC)
Admin / APP Team
Rank: Administration
Groups:
Hope I'm not too late here, although replacing this dishwasher is not a bad idea :)
This Caloric dishwasher was actually made by D & M (Frigidaire). While getting this impeller kit under the "Caloric" brand is pretty much impossible, it is readily available under the Frigidaire brand and we have hundreds in stock.
- Impeller kit for DUS204-19 (instructions included)
UserPostedImage
