2 Pages<12
chicken_sandwich
#11 Posted : Monday, March 1, 2010 4:05:10 PM(UTC)
chicken_sandwich
I found some other sources online, with people having a very similar problem, and some responses advised changing the impeller. Could that be the culprit of my leak and could I do that repair myself?
txrott
#12 Posted : Monday, March 1, 2010 4:11:01 PM(UTC)
txrott
Quiet possible it is in the area you said it was leaking from .. and only like $14.50 for the part..
chicken_sandwich
#13 Posted : Tuesday, March 2, 2010 6:45:07 PM(UTC)
chicken_sandwich
I took apart the plastic housing that holds the impeller. I wanted to see what it would take to disassemble it before I ordered the replacement. I've got it almost completely apart. The one thing i can't seem to get off is the seal. Should it just pull off? Or does it unscrew? I don't want to break anything. Also, with the replacement parts, there is what almost looks like a mini blender blade. I don't have that on my current machine. What is it?
http://www.appliancepartspros.c...9IRUcvc290b2hwdHJhcC8%3d
UserPostedImage
chicken_sandwich
#14 Posted : Tuesday, March 2, 2010 7:16:23 PM(UTC)
chicken_sandwich
I got the seal out. I found some random instructions.
http://www.applianceaid.com/WD19X10032.html
I'm going to order my replacement parts in the morning. I'm wondering, is it common for a seal to go bad and cause a leak like the one I've described?
2 Pages<12
