Floydrat
#1 Posted : Monday, March 1, 2010 8:42:22 AM(UTC)
Floydrat
How do I get to the lower element since it is beneath the metal liner? Do I have to remove the oven from the wall to get to this or is there a procedure that allows me to remove the liner? Thanks
magician59
#2 Posted : Monday, March 1, 2010 10:58:19 AM(UTC)
magician59
If you look real carefully, you'll likely see one or two screws holding the liner in place. They're usually next to the back wall inside the oven. If there are none, all you need to do is slide the liner one way or another to come out. Make sure you unp;ug, or throw the breaker, before you attempt to remove/install an element. 120VAC is always going to one of the terminals.
Floydrat
#3 Posted : Monday, March 1, 2010 3:20:09 PM(UTC)
Floydrat
I looked at the liner and if seems as if the back is welded to the sides. I know on some ovens the bottom piece of the liner is not welded to the sides or back of the liner. The parts manual seems to show the liner as one whole unit, sides, bottom, top, and rear as one piece. I wish sears would allow customers to access the disasembly procedures that their techs use. Thanks
Kitchenaid oven baking element replacement (Oven Repair (including Ranges and Cooktops))
by Rocky D 1/19/2023 5:12:04 PM(UTC)
Frigidaire FES365ECA Stove baking elements will not turn on. (Oven Repair (including Ranges and Cooktops))
by Guest 1/10/2023 9:08:26 AM(UTC)
Kenmore 790.4678 Slide in Range. Baking element not working. (Oven Repair (including Ranges and Cooktops))
by zephlew 5/20/2019 5:21:30 PM(UTC)
Thermador baking element (Oven Repair (including Ranges and Cooktops))
by mianake 10/26/2018 9:02:47 PM(UTC)
by mpd038 3/15/2017 7:10:42 AM(UTC)
Baking element not working but broiler element is working (Oven Repair (including Ranges and Cooktops))
by majeromero 9/15/2015 7:41:26 PM(UTC)
baking element and broiler element not working (Oven Repair (including Ranges and Cooktops))
by davidmb 10/2/2014 6:54:11 AM(UTC)
Baking Element not working after replacing (Oven Repair (including Ranges and Cooktops))
by maxpower2078 8/19/2014 9:30:48 PM(UTC)
Kenmore Elite baking element not heating (Oven Repair (including Ranges and Cooktops))
by candagrm 12/15/2013 9:29:47 AM(UTC)
Need Help Finding Oven Baking Element (Oven Repair (including Ranges and Cooktops))
by tcogsdil 10/21/2013 9:06:56 PM(UTC)
baking element not working - has been replaced (Oven Repair (including Ranges and Cooktops))
by dilemon 5/28/2013 5:48:51 AM(UTC)
Replaced broken baking element , still not working (Oven Repair (including Ranges and Cooktops))
by boonjh 3/12/2013 4:21:16 PM(UTC)
Broken Baking Element (Oven Repair (including Ranges and Cooktops))
by rjansing 12/9/2012 11:20:14 AM(UTC)
kenmore baking element will not turn off (Oven Repair (including Ranges and Cooktops))
by docmartin 11/2/2012 9:48:20 AM(UTC)
Gaggenau baking element (Oven Repair (including Ranges and Cooktops))
by tspat 7/6/2012 9:09:36 AM(UTC)
