My washer will not spin, but it make a sound like the motor is turning but the belt somehow fell off. I believe this is direct drive and does not have a belt though. HELP!:)
If you will post a complete model number someone may be able to help.
If it is a direct drive, the clutch is likely the problem, but you will want to check the drive block also.
Sonia
Please start a new thread with a detailed description of what your machine is doing or not doing, along with a full model number and the brand name.
