Carl Baltensperger
#1 Posted : Monday, August 27, 2007 4:46:56 AM(UTC)
Carl Baltensperger
This dryer runs (drum spins) but never heats up. I just replaced the igniter and 2 coils but no luck. Any suggestions on what I should try next?
Thanks, Carl
Admin / APP Team
#2 Posted : Tuesday, August 28, 2007 8:55:02 AM(UTC)
Admin / APP Team
Rank: Administration
Does the igniter come on (starts glowing) when the dryer is on?
Carl Baltensperger
#3 Posted : Wednesday, August 29, 2007 8:01:04 AM(UTC)
Carl Baltensperger
NO. I watched it for ~5min.
peg
#4 Posted : Wednesday, August 29, 2007 8:23:09 AM(UTC)
peg
I'm peg and I have the same problem with my
Amana Dryer. it's 15 years only and after a short period
time, it only heats for a 5 minutes. what to do?:( :D
Admin / APP Team
#5 Posted : Wednesday, August 29, 2007 8:23:45 AM(UTC)
Admin / APP Team
Check flame sensor for continuity (#13 on this diagram), also check the thermal cut-off (looks like a thermostat, less than an inch in diameter).
Admin / APP Team
#6 Posted : Wednesday, August 29, 2007 8:25:21 AM(UTC)
Admin / APP Team
Doesn't really sound like the same problem, Peg. Click here, then click on the POST NEW TOPIC button and describe your problem in detail. Don't forget to include the model number of your Amana dryer.
Carl Baltensperger
#7 Posted : Thursday, August 30, 2007 6:25:07 AM(UTC)
Carl Baltensperger
The terminal for the white wire on the flame sensor broke off. I had seen the white wire laying there but couldnt figure out where it went and assumed it wasn't being used. Looks like I should try replacing the flame sensor now? I don't see anyway of repairing the broken terminal. Thanks for the guidance, Carl
Admin / APP Team
#8 Posted : Thursday, August 30, 2007 9:18:29 AM(UTC)
Admin / APP Team
If the male terminal, which is part of the sensor, broke off then you'll have to replace the sensor. No way to fix it really.
Good job on finding the problem!
DEPSERV
#9 Posted : Tuesday, September 4, 2007 8:47:04 AM(UTC)
DEPSERV
Thanks, Carl
THE ONLY THING LEFT IS YOUR SAFTY VALVE YOU COULD HAVE PURCHASED A WHOLE NEW BURNER ASSEMBLY THAT WOULD HAVE FIX YOU PROBLEM CALL ME AT ***************
Post edited by admin. Reason: advertising
