jd76
#1 Posted : Wednesday, February 24, 2010 1:54:35 PM(UTC)
jd76
Purchased part number AP3131916 due to codes.
Received new unit and replaced.
LCD display does not iluminate.
Checked connections, seems fine.
Old panel's display worked.
Suggestions?
Thanks!
magician59
#2 Posted : Wednesday, February 24, 2010 7:02:11 PM(UTC)
magician59
Recheck the ribbon connection between the board and display.
jd76
#3 Posted : Thursday, February 25, 2010 6:41:15 AM(UTC)
jd76
The ribon is all the way in, yellow is flush, black clip in place, seems to be making connection. I get sounds when I press the buttons but no LCD. Could there be smoething else to look at or test?
magician59
#4 Posted : Thursday, February 25, 2010 7:52:51 AM(UTC)
magician59
Sounds like you need to replace the control board. Part number: AP3595759
jd76
#5 Posted : Thursday, February 25, 2010 7:57:17 AM(UTC)
jd76
That is the new part I'm asking about.
Whirlpool Control Panel VOM Testing (Washer Repair)
by Guest 10/19/2023 10:23:21 AM(UTC)
Whirlpool Control Panel Replacement Help (Oven Repair (including Ranges and Cooktops))
by Argo 11/8/2018 7:14:17 AM(UTC)
whirlpool control panel switch lighting not working (Refrigerator & Freezer Repair)
by orionengnr 12/30/2016 9:31:49 AM(UTC)
line voltage in old Whirlpool control panel? (Dishwasher Repair)
by Paul_illinois 2/19/2014 7:40:06 AM(UTC)
whirlpool control panel (Oven Repair (including Ranges and Cooktops))
by jcdamante 3/14/2013 3:16:13 PM(UTC)
how to remove a Whirlpool control panel (Oven Repair (including Ranges and Cooktops))
by andrew_80921 10/5/2012 2:17:23 PM(UTC)
Whirlpool Control Panel (Oven Repair (including Ranges and Cooktops))
by gshiple 12/11/2011 12:10:09 PM(UTC)
Whirlpool Control Panel malfuntion (Dishwasher Repair)
by k2hockey 12/13/2010 6:51:32 AM(UTC)
whirlpool CONTROL PANEL BROKE (Oven Repair (including Ranges and Cooktops))
by lacosta75 6/11/2010 7:38:41 AM(UTC)
replacing whirlpool control panel cover (Dishwasher Repair)
by cwl1985 5/13/2010 7:59:37 AM(UTC)
Whirlpool Control Panel Issue? (Dishwasher Repair)
by bermanbj 8/26/2009 7:47:28 AM(UTC)
by vfourider 1/18/2008 8:54:30 AM(UTC)
