My Gold DW stopped in the middle of the cycle and wouldn't respond to any buttons pushed. The next morning it appeard to be on, the indicator lights were on, and the start button flashing. When I pressed start, it went dead. I'm guessing that the electronic control panel is bad. Am I correct:confused:
Check the continuity of the door switch assembly. Also check to see if the door is latching properly.
Thanks Magician. I checked the door switch and it is working properly:)
Then it sounds like a bad control board.
Thanks, I think you're right. I'm going to test a few things just for practice (my multi meter just blew up), and then probably order one.
