roubacon
#1 Posted : Wednesday, February 24, 2010 4:57:43 AM(UTC)
roubacon
Dryer heat only comes on sometimes. I pulled the back cover off thinking it was something to do with the ignition. The ignitor glows red but no flame. I removed the gas line believing it was clogged and then reconnected it; the dryer then worked and I thought the problem was solved. Not sure where to go from here, is this a timer issue or something else?
magician59
#2 Posted : Wednesday, February 24, 2010 7:28:59 AM(UTC)
magician59
Sounds like it could be weak coils. Here's the part number for the kit. Part number: AP2150379
Ge Front Load Dryer Will Not Dry Clothes (Dryer Repair)
by Tiff 7/10/2012 6:06:35 PM(UTC)
Dryer will not dry (Washer Repair)
by jciezk1 2/4/2011 5:26:46 PM(UTC)
maytag dryer will not dry properly (Dryer Repair)
by dutchstl 10/28/2009 11:17:55 AM(UTC)
Dryer will not dry, but will rotate (Dryer Repair)
by Freddy Rivera 8/29/2009 11:25:08 AM(UTC)
Stacker Dryer will not Dry Clothes (Dryer Repair)
by cvm 5/20/2009 6:55:48 PM(UTC)
dryer will not dry clothes (Dryer Repair)
by roycheste 2/18/2009 10:22:02 AM(UTC)
Dryer will not dry when attached to vent. (Dryer Repair)
by uk2us88 8/4/2008 11:25:09 AM(UTC)
