laxnkio
#1 Posted : Tuesday, February 23, 2010 1:10:06 PM(UTC)
laxnkio
Hello, I own a Kenmore Flat Cooktop Oven/Range with a malfunctioning front left large burner. The burner stays on indefinitely if I turn it on, and need to unplug the oven to turn it off. (sometimes that doesnt even work) From your site it looks like its a broken infinity switch. I searched my model number (Kenmore 790.96129409)using your search but did not locate anything. If you could point me to the correct replacement product I would appreciate it. Thank you for your time
#2 Posted : Tuesday, February 23, 2010 3:32:42 PM(UTC)
Most likely the problem is a bad infinite switch for the burner.
- The dual element switch Part number: AP2126649
laxnkio
#3 Posted : Tuesday, February 23, 2010 3:40:29 PM(UTC)
laxnkio
Just a quick follow up question...the product you posted is for a dual element...my dual element burner (small and large) is the bottom right burner which is working perfectly. Do i need the same dual element replacement switch for the bottom left burner, which is large only? Thanks!
#4 Posted : Tuesday, February 23, 2010 4:05:35 PM(UTC)
Sorry, I posted the wrong part number.
The infinite switch for the large element Part number: AP2591804
This is a universal switch, used as replacement part by the manufacturer. It comes with the installation instructions.
laxnkio
#5 Posted : Tuesday, February 23, 2010 4:46:59 PM(UTC)
laxnkio
Thank you very much for the help.
#6 Posted : Tuesday, February 23, 2010 6:05:14 PM(UTC)
etdrew27
#7 Posted : Thursday, August 12, 2010 10:12:50 AM(UTC)
etdrew27
But my model # is Kenmore 79096009601. Would this same switch work for me?
#8 Posted : Thursday, August 12, 2010 3:58:06 PM(UTC)
Yes, it would for the rear burners.
