upacreek
#1 Posted : Monday, February 22, 2010 5:35:44 AM(UTC)
upacreek
Where does the spring that attaches to the damper door also attach too? My son was "helping" me, however, the screw driver poking in from the freezer side was not the help I needed. I now have a damper door and small spring and no idea as to where they go or how they attach to refrigerator /freezer. I'm assuming the damper door ( plastic rectangle flap) goes inside the styrofoam, and I see where the spring would attach to the door damper< but after that I'm at a lost as to where the spring goes to retrack the door open and close :confused: . Thanks
#2 Posted : Monday, February 22, 2010 9:33:08 AM(UTC)
Here is a picture, click on it to expand it.
Part number: AP4069713
upacreek
#3 Posted : Monday, February 22, 2010 7:09:47 PM(UTC)
upacreek
Denman thank you very much, with your advise I expanded the picture and found that the other end of the spring fitx into the white plastic house frame.Thank you !:) Can you please help with next step too?The refrigerator is still giving me trouble, Ive replaced the adaptive defrost control and frig side is still running warm ( about 50 deg) freezer is cold and making ice cubes thou? What eles can or should I check for? How long will it take for an empty frig for an accurate tempurature reading?
#4 Posted : Tuesday, February 23, 2010 6:52:31 AM(UTC)
[COLOR="Blue"]What eles can or should I check for?[/COLOR]
I would check that the freezer temperature is close to 0 degrees F.
Check that the compressor and it's fan are running.
Check that the evaporator fan is running.
Check that the damper door is open.
[COLOR="Blue"]
How long will it take for an empty frig for an accurate temperature reading?[/COLOR]
I would give it at least 24 hours.
