jrebelo1494
#1 Posted : Monday, April 7, 2008 2:21:59 PM(UTC)
jrebelo1494
The above GE Model Stove needs to have the oven door gasket replaced. How difficult would this replacement be and are there any instruction which I could follow to replace the gasket.
#2 Posted : Tuesday, April 8, 2008 12:37:32 PM(UTC)
The oven door gasket is not too difficult a part to replace yourself.
Remove the oven door as described in the "Use and Care Manual" (page 35) and place it on a flat surface with the front of the door facing down.
Remove all screws holding the inner door panel and remove the inner door panel to access the door gasket.
- The part number for the oven door gasket is AP3853071
