The above GE Model Stove needs to have the oven door gasket replaced. How difficult would this replacement be and are there any instruction which I could follow to replace the gasket.
The oven door gasket is not too difficult a part to replace yourself. Remove the oven door as described in the " Use and Care Manual" (page 35) and place it on a flat surface with the front of the door facing down. Remove all screws holding the inner door panel and remove the inner door panel to access the door gasket. - The part number for the oven door gasket is AP3853071 Gene.
