Hello I have a Rpoer coin op dryer the motor does not come on but the electric element does. I replaced the motor stilll same problem! Any ideas what I should check next? :confused:
check to see if the heating element is shorted to the frame. is the element on at all times or only when you push start? and does the motor hum at all when you push the start button?
Originally Posted by: Qtip  check to see if the heating element is shorted to the frame. is the element on at all times or only when you push start? and does the motor hum at all when you push the start button? The motor makes no noise ant all and the element is on all the time thanks for reply I'm going yo check the element now.
i'm assuming you know how to check that but if not you'll want to set your meter to continuity and pull the wires off the heating element then put one lead where the wires connect and the other on the casing that holds the heating element - if you get continuity that way then the element is shorted and you'll need to replace it whether it fixes your original problem of not starting or not.
