vebl2000
#1 Posted : Wednesday, February 10, 2010 2:36:28 PM(UTC)
vebl2000
Help.............. My gas oven will not bake or broil. The ignitor clicks as if is it working but no visible spark. Very little gas if any is smelled. Used lighter on broiler to see if tube would light and it did very briefly. The bake didn't work at all. The oven is at least 6yrs old
#2 Posted : Wednesday, February 10, 2010 5:03:01 PM(UTC)
What is the complete model number of the range?
vebl2000
#3 Posted : Saturday, February 20, 2010 2:22:55 PM(UTC)
vebl2000
Sorry Gene, I was on a business trip. The model number is GS440LEMQ. I verified the door switch is functional. After reading another help blog we tested the output of the bake & broil ignitors from the spark module. The 120V suggested was not found. We replaced the spark module and the same problem exists. What have I over looked?
#4 Posted : Saturday, February 20, 2010 3:15:29 PM(UTC)
The first thing I would do is check the solenoids on the gas valve/regulator (#15 on the diagram). You can find more instructions and useful information in one of our previous posts: http://forum.appliancepartspros...l-oven-wont-heat-up.html
- The gas valve/regulator Part number: AP3866825
Here are the breakdown diagrams and Replacement parts for WHIRLPOOL GS440LEMQ0 30" Gas Freestanding Self Clean Range Sealed Burner | AppliancePartsPros.com
P.S. Replacing the spark module without proper troubleshooting is very common mistake.
