topgun
#1 Posted : Tuesday, February 16, 2010 5:53:27 AM(UTC)
topgun
First of all I'm not sure of the age because I wasn't left the owner's phamplet. The water dispenser is not working. I cleaned out all of the ice and turned down the number to a 3 thinking it may be a frozen water line. Now It's not making ice either. What will the repair entail and is it worth it. It's already taken a new mother board 7 months ago.
#2 Posted : Tuesday, February 16, 2010 7:09:34 PM(UTC)
Perform the troubleshooting as described in the attached instructions and post the results.
Here are the breakdown diagrams and Replacement parts for General Electric GSS20IEMBWW Refrigerator | AppliancePartsPros.com
File Attachment(s):
Water is not dispensing.pdf (394kb) downloaded 5 time(s).
1carnut
#3 Posted : Saturday, February 20, 2010 6:38:26 AM(UTC)
1carnut
While trying to unfreeze the supply line for the subject freezer, I damaged the line and am trying to replace it. I can't figure out how to get the door apart to get to the line.
#4 Posted : Saturday, February 20, 2010 12:58:38 PM(UTC)
There are screws around the inner door liner, under the door gasket. The door has to be removed from the refrigerator prior to disassembly.
Here are the breakdown diagrams and Replacement parts for General Electric GSH25KGMCAA Refrigerator | AppliancePartsPros.com
#5 Posted : Saturday, February 20, 2010 1:04:04 PM(UTC)
There are a few screws around the inner door liner, under the door gasket. The door has to be removed from the refrigerator prior to disassembly.
GE Side by Side Refrigerator Model GSS25IYNXHFS dim LED lights (Refrigerator & Freezer Repair)
by jhauter 5/15/2024 4:30:46 AM(UTC)
GE side by side refrigerator freezer not cooling (Refrigerator & Freezer Repair)
by ReddogRudy 6/10/2018 3:21:06 PM(UTC)
GE side by side refrigerator not holding temperature (Refrigerator & Freezer Repair)
by Jmatthew33 7/8/2014 8:06:56 PM(UTC)
Power coupling/ power line harness. GE side by side refrigerator. (Refrigerator & Freezer Repair)
by Skully2014 7/24/2013 12:00:57 PM(UTC)
GE side by side refrigerator/freezer (Refrigerator & Freezer Repair)
by Mprior 4/27/2011 9:16:06 AM(UTC)
GE Side by Side Refrigerator (Refrigerator & Freezer Repair)
by trimbo 3/23/2011 11:26:12 AM(UTC)
GE side by side refrigerator both temp show 75 degree help (Refrigerator & Freezer Repair)
by lucky_me 2/6/2010 12:57:39 AM(UTC)
GE side by side refrig tfh22prsm ww leaking from bottom, no longer cold either side (Refrigerator & Freezer Repair)
by thomashaskins 9/4/2009 11:58:49 AM(UTC)
GE side by side refrigerator (Refrigerator & Freezer Repair)
by Samhill 7/23/2009 5:37:41 AM(UTC)
GE side by side refrigerator dispensor dripping (Refrigerator & Freezer Repair)
by mjl 7/19/2009 6:32:44 PM(UTC)
GE side by side refrigerator not dispensing ice (Refrigerator & Freezer Repair)
by philly09 4/21/2009 3:14:48 PM(UTC)
GE Side by Side Refrigerrator (Refrigerator & Freezer Repair)
by Endsley 4/20/2009 7:49:17 AM(UTC)
by shirleymillan 3/12/2009 5:33:43 PM(UTC)
ice shoot flap won't close on ge side by side refrigerator (Refrigerator & Freezer Repair)
by amyp 10/23/2007 6:34:51 AM(UTC)
