Seattle2010
#1 Posted : Wednesday, February 17, 2010 8:12:09 PM(UTC)
Seattle2010
Hi Gene, this forum is very helpful and informative. Thank you
I need a new defrost timer for my old GE refrigerator. My question is can I replace a 6hr. timer with a 16hr or 10hr timer? How does the refrigerator determine if the defrost system is working? This unit has a DE alarm system. Thank you for your help
#2 Posted : Thursday, February 18, 2010 3:09:20 AM(UTC)
The defrost timers are selacted to give complete defrost under worst case thermal environments.
Your timer is a 6 hr, 25 min defrost period, it runs for 6 hours, then defrosts for 25 minutes. You should use a similar timer to prevent problems.
If you want a more robust timer, you can stick in a the GE timer WR9X330DS which has a 6 hr defrost period and a 21 minute defrost time. This timer is $10 cheaper, but it will make a whiring sound in the control panel that some object to.
Seattle2010
#3 Posted : Thursday, February 18, 2010 6:30:58 AM(UTC)
Seattle2010
Great. Thank you Gene. But can you also tell me how the Defrost Alarm getting trigger? Is it from the 6HR timer? Will a longer defrost timer trigger Defrost Timer?
#4 Posted : Thursday, February 18, 2010 9:49:26 AM(UTC)
I believe most of these alarms are triggered by a high refrigerator temperature and not by any defrost timer.
