awelsch
#1 Posted : Tuesday, February 16, 2010 8:18:39 AM(UTC)
awelsch
I have a refriderator that stops cooling. If I power cycle it by unplugging the AC it starts cooling again, for a short time. I can also get it to start working again by rotating the thermostat off then back on.
#2 Posted : Tuesday, February 16, 2010 11:37:21 AM(UTC)
Would it start if you tap on the thermostat or jiggle the thermostat knob?
If it would, replace the thermostat.
If it would not, the problem most likely is a bad ADC board (#4 on the diagram).
- The thermostat Part number: AP3084361
- The ADC Part number: AP3853127
awelsch
#3 Posted : Tuesday, February 16, 2010 11:43:24 AM(UTC)
awelsch
Thank you for the information. I will try that when I get home tonight.
awelsch
#4 Posted : Monday, March 29, 2010 8:16:41 AM(UTC)
awelsch
Thank you for the assistance. I replaced the thermostat and the fridge works properly again.
#5 Posted : Monday, March 29, 2010 11:59:19 AM(UTC)
You are welcome. I'm glad you were able to fix it. Thank you for the feed back.
