j.clayton
#1 Posted : Friday, February 12, 2010 12:35:45 PM(UTC)
j.clayton
Background on my problem:
1. My oven started beeping for no reason.
2. I was told to replace the Electronic Range Control part #WB27K5344.
3. I received a GE replacement part #2084360010 (model#'s 164D5063P004, and WB27T10492).
4. I received the part but it did not include a way to conect the control panel 14 point ribbon to the Electronic Range Control.
5. Do I need to replace the entire control panel or can I get a connection for the ribbon?
6. If I do buy a new control panel will it come with the ribbon connector?
Thank You for your help! Jim
#2 Posted : Friday, February 12, 2010 4:51:09 PM(UTC)
This is a duplicated thread.
Answered here: http://forum.appliancepartspros...lacement.html#post189534
Kenmore Gas Oven Control Panel replacement (Oven Repair (including Ranges and Cooktops))
by j.clayton 2/12/2010 12:34:17 PM(UTC)
