batesville
#1 Posted : Wednesday, February 10, 2010 6:29:05 PM(UTC)
batesville
Front loader washer that won't go into a high speed spin. Plenty of clothes in the washer so it's not too light
sidfink43
#2 Posted : Friday, February 12, 2010 6:55:41 AM(UTC)
sidfink43
If you post a complete model number someone should be able to help.
batesville
#3 Posted : Sunday, February 14, 2010 5:05:18 PM(UTC)
batesville
I believe the model number is 417-44102300.
sidfink43
#4 Posted : Monday, February 15, 2010 5:19:18 AM(UTC)
sidfink43
Ok, good. This is a Frigidaire Gallery washer sold under the Kenmore Brand name.
You should check your speed control board, and your main control board but the speed control board is the more likely problem.
Here is a service manual that will show you how to do that. Sometimes the tests are inconclusive, though and you just have to replace a part on speculation.
http://frigidaireservicetips.co..._TumbleActionWashers.pdf
small leak under Kenmore front loader (Washer Repair)
by SteveNathan 3/20/2022 8:57:17 AM(UTC)
Kenmore front loader normal cycle (Washer Repair)
by Christobevii3 5/4/2015 1:51:38 PM(UTC)
Kenmore front loader will not consistently drain (Washer Repair)
by Mbmiller34 1/16/2015 10:08:24 AM(UTC)
Kenmore Front Loader (Washer Repair)
by mbrown7776 10/9/2014 7:11:53 AM(UTC)
Kenmore Front Loader, no power (Washer Repair)
by Sean1981 2/28/2014 1:53:40 PM(UTC)
Noisy Kenmore Front Loader Producing Grit? (Washer Repair)
by p_40ace 11/20/2013 5:58:46 PM(UTC)
Kenmore front loader won't spin fast (Washer Repair)
by Bill79 8/12/2013 2:56:41 PM(UTC)
Kenmore front loader washer spins but doesn't drain (Washer Repair)
by SweetiePTMary 12/17/2012 10:17:20 AM(UTC)
Kenmore Front loader no water coming in (Washer Repair)
by tammyjen 10/1/2012 11:24:26 AM(UTC)
Kenmore Front Loader tub assembly (Washer Repair)
by jwmark 11/1/2011 6:24:15 AM(UTC)
Kenmore Front Loader Door Switch testing (Washer Repair)
by Ned Lesh 9/26/2011 9:12:11 AM(UTC)
by rchmd 7/21/2011 6:36:27 PM(UTC)
Kenmore front loader won't spin (Washer Repair)
by 71bob71 4/20/2011 5:06:33 PM(UTC)
kenmore front loader wont spin or agitate (Washer Repair)
by rrpackageplus 3/24/2011 11:44:43 AM(UTC)
Error code 02 for kenmore front loader (Washer Repair)
by jrallo3789 10/20/2010 6:14:51 PM(UTC)
