rchmd
#1 Posted : Thursday, July 21, 2011 6:36:27 PM(UTC)
rchmd
The belt came off. When I put the belt back on the drum does not spin or spins a little then stops.
sidfink43
#2 Posted : Saturday, July 23, 2011 6:00:45 PM(UTC)
sidfink43
The belt should not have come off. Check to see if there is any play in the pulley and try replacing the belt as it may have stretched.
small leak under Kenmore front loader (Washer Repair)
Belarus SteveNathan 3/20/2022 8:57:17 AM(UTC)
Kenmore front loader normal cycle (Washer Repair)
by Christobevii3 5/4/2015 1:51:38 PM(UTC)
Kenmore front loader will not consistently drain (Washer Repair)
by Mbmiller34 1/16/2015 10:08:24 AM(UTC)
Kenmore Front Loader (Washer Repair)
by mbrown7776 10/9/2014 7:11:53 AM(UTC)
Kenmore Front Loader, no power (Washer Repair)
by Sean1981 2/28/2014 1:53:40 PM(UTC)
Noisy Kenmore Front Loader Producing Grit? (Washer Repair)
by p_40ace 11/20/2013 5:58:46 PM(UTC)
Kenmore front loader won't spin fast (Washer Repair)
by Bill79 8/12/2013 2:56:41 PM(UTC)
Kenmore front loader washer spins but doesn't drain (Washer Repair)
by SweetiePTMary 12/17/2012 10:17:20 AM(UTC)
Kenmore Front loader no water coming in (Washer Repair)
by tammyjen 10/1/2012 11:24:26 AM(UTC)
Kenmore Front Loader tub assembly (Washer Repair)
by jwmark 11/1/2011 6:24:15 AM(UTC)
Kenmore Front Loader Door Switch testing (Washer Repair)
by Ned Lesh 9/26/2011 9:12:11 AM(UTC)
Kenmore front loader won't spin (Washer Repair)
by 71bob71 4/20/2011 5:06:33 PM(UTC)
kenmore front loader wont spin or agitate (Washer Repair)
by rrpackageplus 3/24/2011 11:44:43 AM(UTC)
Error code 02 for kenmore front loader (Washer Repair)
Belarus jrallo3789 10/20/2010 6:14:51 PM(UTC)
Kenmore front loader won't drain or spin (Washer Repair)
by twbrans 8/3/2010 2:15:22 PM(UTC)
