wmako
#1 Posted : Wednesday, February 10, 2010 2:41:04 PM(UTC)
wmako
How do I access and remove the ciruclation motor, pump, and impleller on a Bosch SHU6806UC/12 . I suspect a problem with one of them and would like to remove to check/inspect. I have removed the right side cover, and see everything. Do I need to somehow separate the tub from the base?
I came accross this post
http://forum.appliancepartspros...hoto-supposed-there.html
which talks about removing the pump on a SHU3336 UC/12 and even incudes a word document with instructions. Do these instructions also apply to my SHU6806UC/12? It looks similar.
Any help is greatly appreciated! :)
#2 Posted : Wednesday, February 10, 2010 5:32:59 PM(UTC)
Yes, you can use the same instructions. These models are very similar.
Here are the breakdown diagrams and Replacement parts for Bosch SHU6806 UC/12 (FD 8003-) | AppliancePartsPros.com
wmako
#3 Posted : Thursday, February 11, 2010 6:00:27 AM(UTC)
wmako
Thanks Gene,
It doesn't look like I have as much room to work from the side of the dishwasher as in the instructions. Are you sure I don't have to remove the base? Any one have insturctions for this?
#4 Posted : Thursday, February 11, 2010 4:21:43 PM(UTC)
It is up to you. It would not do any bad if you remove the base on this side. I do not think you have to remove it completely.
wmako
#5 Posted : Saturday, February 13, 2010 5:11:49 AM(UTC)
wmako
Thanks Gene - I removed two screws from the back, and four from the front. I laid the dw on it's back, and pulled the base away from the tub about 3-4 inches. This gave me enough room to pull off the motor for the circulation pump.
