How do you replace the board that controls the clock and oven at the top.:)
Before we proceed I would like to know what is the original problem with your range.
This just started,but I have found that every time I turn the tv on the clock on the oven either starts blinking or trys to go out. And you also can't use the oven when this is going on. I have been through this about 25 times but every time the t.v. is turned on the clock goes acting up. I have even tried turning the t.v. on without a remote but the same problem . And also, the oven is on it's on power wired to it's on electic box outside. SO CAN YOU PLEASE TELL ME WHAT THIS IS!!!!!!!!!!!!!!!!!!!! P.S. This sounds like:eek: something Rod Stirling would have in the TWLIGHT ZONE!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!:mad::mad::eek::eek:
I do not think there is a problem with the oven control board.
Most likely something is wrong with power supply for the oven and/or TV. You have to call a certified electrician to check the breaker box and the outlets inside.
Thankyou, Iguess I will have to do that.
