2 Pages12>
mbukrinsky
#1 Posted : 17 years ago
mbukrinsky
I have Bosch WFK2401 washer. It is stuck with 1 cycle remaining and the door locked. Nothing is blinking, and the door does not open, even if I turn the power off. If I change the program, it goes through the cycles normally, until 1 cycle remains and then stops. There is no water in the washer. Does anybody know what the problem can be, and at least how to open the door? Thank you
#2 Posted : 17 years ago
Enter the test program by:
1. Set the cycle knob to any "X" (reset) position
2. Press and hold the Pre-wash and the Start buttons at the same time. While still holding these buttons, turn the unit on by pressing the On/Off button
3. Keep holding the Pre-wash and the Start buttons until the digital display comes on (about 5 seconds)
The digital display will show 00 for no faults or will show a fault code.
To end the test program turn the washer off at any time.
Post the results.
mbukrinsky
#3 Posted : 17 years ago
mbukrinsky
Thanks Gene. I did the test and it shows 06. What does it mean? Mike
#4 Posted : 17 years ago
The fault code "06" means "Door open or won't lock". Something wrong with the door lock.
I do not know this model good enough to guide your further. Maybe someone else on the forum can help you better.
ranchero
#5 Posted : 15 years ago
ranchero
Using Gene's procedure, I'm coming up with a code 08. Anyone know what that means? By the way, the machine fills and drains but will not agitate. I can hear a faint clicking sound from the top of the washer when it should be spinning Belt is good and motor, drum and belt spin freely.
Steve
#6 Posted : 15 years ago
Hi Steve,
The "08" fault code means "Drum motor won't run".
Check how drum rotates. If drum wobbles or won’t move, replace faulty rear bearing.
Check voltage at motor connectors when motor is energized. If low or no voltage, replace faulty control module.
Check voltage at motor connectors when motor is energized. If ~ 240V, replace faulty drum motor.
Check voltage at motor connectors when motor is energized. If voltage doesn’t reverse, replace faulty control module.
Here are the breakdown diagrams and Replacement parts for BOSCH WFK2401 | AppliancePartsPros.com
ranchero
#7 Posted : 15 years ago
ranchero
Gene - thanks for your reply! Turns out that replacing the brushes did the trick!
Steve
#8 Posted : 15 years ago
You are welcome Steve. I'm glad you were able to fix it. Thank you for the feedback and good luck with your washer.
rlmelander
#9 Posted : 14 years ago
rlmelander
I have a similar problem and I get error code 01 any idea what it means?
#10 Posted : 14 years ago
The error code "01" means "no water filling".
Make sure the water supply is on and the incoming water pressure is between 14.5 - 145 psi.
Measure the resistance of the water inlet valves. The normal reading suppose to be between 2.7 - 3.3 KOhms. If the reading is incorrect, replace the water inlet valves.
Check the voltage output to the water inlet valves while they are energized. If no voltage, replace the control module.
The model number you posted is incorrect. If you need the correct part numbers, verify the model number and repost it.
2 Pages12>
