frj
#1 Posted : Sunday, March 30, 2008 10:01:45 AM(UTC)
frj
i remove the motor for my washer awm352w, but know i forget its connection to its start clutch switch
is there any way to find it
looking forward:o
#2 Posted : Monday, March 31, 2008 9:37:53 AM(UTC)
Look for the wiring diagram inside the control panel. Otherwise it could be a big problem because there is not much information on-line.
Here are the break down diagrams for the Speed Queen washer Model AWM352
frj
#3 Posted : Tuesday, April 1, 2008 6:43:34 AM(UTC)
frj
Threr is no diagrame inside ,
on motor there is centrfuge switch with cables color lable for motor side, what about if match the same color wires on other side too?
#4 Posted : Tuesday, April 1, 2008 7:41:27 PM(UTC)
It can work. Also look for marks on the switch cover.
frj
#5 Posted : Sunday, April 6, 2008 6:45:16 AM(UTC)
frj
Sir,
centrifuge switch have cables color label for motor side, BUT i am not confirm the color scheme for other side.
