i remove the motor for my washer awm352w, but know i forget its connection to its start clutch switch is there any way to find it looking forward:o
Look for the wiring diagram inside the control panel. Otherwise it could be a big problem because there is not much information on-line. Here are the break down diagrams for the Speed Queen washer Model AWM352Gene.
Threr is no diagrame inside ,
on motor there is centrfuge switch with cables color lable for motor side, what about if match the same color wires on other side too?
It can work. Also look for marks on the switch cover.
Sir, centrifuge switch have cables color label for motor side, BUT i am not confirm the color scheme for other side.
