onenwalsh
#1 Posted : Monday, March 31, 2008 1:28:10 PM(UTC)
onenwalsh
I have a General Electric gas oven JGBP35, the oven does not get up to the proper heat. I changed the Tempature sensor and it still doesn't work. The oven egnitor works the burner goes on for 10-20 seconds and then turns off, about 3-4 minutes later it goes back on for 10-20 seconds. Any ideas?
#2 Posted : Tuesday, April 1, 2008 2:19:15 PM(UTC)
Most likely the problem is a bad oven control. In order to provide the right part number I need the rest of the model number.
victor borcea
#3 Posted : Wednesday, April 2, 2008 3:32:26 AM(UTC)
victor borcea
I have same problem but nobody want to help me and i have the exact model nr.I think the don`t know.
onenwalsh
#4 Posted : Wednesday, April 2, 2008 11:30:12 AM(UTC)
onenwalsh
Hi Gene,
Thanks for responding. The entire model number is JGBP35GEP3WG
#5 Posted : Wednesday, April 2, 2008 4:49:35 PM(UTC)
Hi onenwalsh,
The part number for the control board (without overlay) is AP2632694
The overlay is no longer available. You have to be careful not to damage it when you'll remove it from the old control board. It is selfadhesive.
