kdl
#1 Posted : Monday, February 8, 2010 10:39:42 AM(UTC)
kdl
I have read a ton about the defrost process. I found that I can force defrost mode by toggling the light switch 5 times in 6 seconds. And the evaporator heater works great (the burn on my finger being proof). Since my fridge uses a bimetal thermostat, and doesn't have a timer, but a control board (I believe). Does the fact that it goes into defrost inidicate the bimetal thermostat is okay? I tried to take it out to check it w/ meter, but cant get the pins out of the plug, so I'm leary of damaging it if its working perfectly. Any help / advice is greatly appreciated.
squier3
#2 Posted : Monday, February 8, 2010 5:05:00 PM(UTC)
squier3
You will need to replace the adaptive defrost timer. (241736601)
kdl
#3 Posted : Wednesday, May 26, 2010 2:36:11 PM(UTC)
kdl
I've been defrosting by toggling the light switch and forcing the cycle. But now that won't work. I haven't replaced the adaptive defrost control yet - should I get the thermostat defrost now as well? Maybe forcing it made it go bad? Help?
kdl
#4 Posted : Wednesday, June 23, 2010 9:43:05 AM(UTC)
kdl
help! I replaced the adaptive defrost timer per your suggestion. When I plugged it in, it heated the coils immediately. I thought my fridge was going to be great! So I didn't check it but 6 days later, it was warm in the fridge side and I opened the freezer side to see a ton of frost. Now when I click the switch to try and force it, it won't force it. Any ideas? Could it possibly be the wiring harness? This fridge is only 2 years old and looks brand new! Thanks!
pinoy_ako
#5 Posted : Wednesday, June 23, 2010 8:08:19 PM(UTC)
pinoy_ako
Timer must be replace-
May pilipino ba dito. I-pm nyo ako nang magkakilala tayo. Magtayo tayo ng samahan or grupo. Mag usap tayo sa internet. Or gumawa tayo ng forum na pang pinoy.
