KEVINBKEVIN
#1 Posted : 17 years ago
KEVINBKEVIN
NEED HELP....My problem started as a no heat problem (Everything worked but gave a loud humming sound and no heat) I tested the capacitor, mag, transformer, diode, interlock switches and all seemed ok except the diode seemed a little heat discolored on one end so I replaced. After replacing the diode and hooking everything back up when I closed the door a humming started.(Stops when I open door). Recheched my conections to the schematic and I do have everything hooked up correctly. Checked the interlock switches again and they check ok. So I unhooked the primary connections on the transformer and with the door closed I get about 130 volts going to the transformer as soon as the door shuts.(does this indicate a board problem?). thank you for any advice:)
glen65
#2 Posted : 17 years ago
glen65
A louder than usual humm most of the time is a problem in the high voltage
secondary circuit.
Put all of the primary connections back on the transformer.
Then disconnect the leads from the mag
“MAKE SHURE THEY ARE ISOLATED AND NOT TOUCHING YOU OR ANYTHING IN THE MICRWAVE CASE” then start the microwave.
If the loud humm goes away then you most likely have a bad mag.
KEVINBKEVIN
#3 Posted : 17 years ago
KEVINBKEVIN
I Will Try That But As To The Humming Starting By It Self As Soon As I Shut The Door Is That Normal? Thanks
glen65
#4 Posted : 17 years ago
glen65
No,
You may have more than one problem with the unit.
It’s possible you have a relay on the circuit board
that’s sticking in the closed (or on ) position.
KEVINBKEVIN
#5 Posted : 17 years ago
KEVINBKEVIN
Ok, ran through a on off cycle and it seemed I did have a stuck relay....now I am back to everything works but no heat.....pulled leads off of mag and ran...no humming. Does this mean the mag is bad for sure?(pulled mag out and found no signs off arcing on anttenna or waveguide looks great). another thing is that I can never get a discharge out of the capacitor with a screwdriver even seconds after I run the microwave.could the mag be causing that too?
Thanks for all your advice
glen65
#6 Posted : 17 years ago
glen65
It’s a bit tough to be 100% when you’re
trying to fix stuff over the net.
But if you’re getting a real loud humm, and you
know you’re getting the high voltage to the
mag that you’re supposed to be getting then the mag
is no good. The excess hum is because of the fact that
the secondary circuit is being loaded down more than normal.
Now if you were to pull the wires off of the mag and you
were to still get a loud hum then you would need to suspect
one of the other secondary high voltage components.
That doesn’t necessarily mean it’s good.
Most of the bad ones I’ve ran into don’t
usually show any visible signs of damage.
Its possible,
If there is a problem with the mag it could act as a short.
Dont forget there's also a bleed resistor built into the cap.
No problembo
KEVINBKEVIN
#7 Posted : 17 years ago
KEVINBKEVIN
Hey Glen65, well I called GE and found out the mag. is warrentied for 10 years and mine is nine years old so they are sending me kit # wb27x10489 for free...it comes with mag,stirrer,and diode. Thanks for all your help!!! Hopefully this will fix my problem....FYI the number I called is 1-800-437-9283...At first they tried to say I had to have a GE authorized person look at it, but then they got me in touch with the right department and kit is on its way!!!!!!!
glen65
#8 Posted : 17 years ago
glen65
Good deal,
That kit retails for well over 100 bucks depending
on where you get it. I am a bit surprised they didn’t
insist that you seek out a warranty authorized service
person to get it covered. That’s because it’s standard
procedure to file warranty paperwork by the tech.
I know you already replaced the diode, but I would
make sure to replace it again with the one that comes
in the kit. Make sure you observe the proper polarity
of the diode. Let us know how you make out.
Kitchenaid Oven range Superba kgsc308lss0 not heating up (Oven Repair (including Ranges and Cooktops))
by rattty 9 months ago
Glass washer not heating up (Dryer Repair)
by Guest 9 months ago
Gas Oven not heating up (Oven Repair (including Ranges and Cooktops))
by Guest about a year ago
Still not heating (Dryer Repair)
by artinmartin about a year ago
new heating element, but still not heating (Dishwasher Repair)
by ScotofBV 2 years ago
How to diagnose Thermador gas oven PG366BS not heating? (Oven Repair (including Ranges and Cooktops))
by Guest 2 years ago
GE Dryer Not Heating - Model: GFDS140ED0WW (Dryer Repair)
by laflair13 2 years ago
Kenmore Elite HE3 not heating and drum not spinning (Dryer Repair)
Thermadore PRG304GH oven not heating (Oven Repair (including Ranges and Cooktops))
upper oven not heating up to desired temp. it's off by about 50 degrees (Oven Repair (including Ranges and Cooktops))
GE Microwave Louder and Not Heating PEB7226SF2SS (Microwave Repair)
by Guest 3 years ago
Samsung Gas Dryer Model DV42H5000GW/A3 not heating (Dryer Repair)
by mikeb22 3 years ago
Whirlpool double wall oven lower not heating (Oven Repair (including Ranges and Cooktops))
by mid 3 years ago
Samsung DV395ETPASU/A1 not heating (Dryer Repair)
Bosch washer not heating (Washer Repair)
