mag356
#1 Posted : Monday, March 31, 2008 11:01:14 AM(UTC)
mag356
I am needing help in troubleshooting a problem with our washing machine. When we set the time dial to a timed cycle and pull the knob out, nothing happens. Normally, this would activate the washer to start filling with water and then proceed to the agitation cycle, etc. If we turn the knob to the "rinse" or "spin" position, then it does activate the machine and it either starts filling with water or begins spinning.
Because of these "symptoms", I believe the timer is bad and want to replace it. Can someone please advise if my diagnosis is correct? Thanks.
fixtec90
#2 Posted : Tuesday, April 1, 2008 4:24:40 AM(UTC)
fixtec90
Classic machine!
Your diagnosis sounds like its on the money. Being the true classic it is you shouldn't have any trouble finding a timer.
mag356
#3 Posted : Tuesday, April 1, 2008 6:13:40 AM(UTC)
mag356
Thanks, Fixtec90.
Guest (4)
Alternate timer control for older Maytag top load washer ModelLAT8210AAW (Washer Repair)
by Guest 7/7/2023 12:43:57 PM(UTC)
Replacing the timer control (Washer Repair)
by Alanmichie 8/25/2011 9:37:04 AM(UTC)
Gas Dryer Heating Issue - Timer controlled by thermostat? (Dryer Repair)
by FIY 5/9/2011 7:45:21 PM(UTC)
How to remove the Timer Controller Dial (Washer Repair)
by ralphW 3/5/2011 7:47:17 AM(UTC)
Whirlpool Range Timer Control 9751345 burnt (Oven Repair (including Ranges and Cooktops))
by tailor 1/24/2011 7:21:00 PM(UTC)
GE timer control (Oven Repair (including Ranges and Cooktops))
by watelec 1/24/2011 5:44:37 AM(UTC)
timer control or something else? (Dryer Repair)
by bmille 11/18/2010 2:56:18 PM(UTC)
Timer control does not advance (Dryer Repair)
by REB2_58 8/8/2010 5:37:47 AM(UTC)
Timer Control knob replacement (Washer Repair)
by BillandJeanne 3/9/2010 2:58:17 PM(UTC)
timer control or water level control? (Washer Repair)
by Elehairyjob5 2/18/2010 6:13:30 AM(UTC)
Electronic Timer Control (Oven Repair (including Ranges and Cooktops))
by DSTEALT@AOL.COM 12/3/2009 4:46:28 PM(UTC)
Estate timer control problems (Washer Repair)
by lbermud 4/27/2009 5:48:38 PM(UTC)
Frigidaire Timer Control Panel - Range (Oven Repair (including Ranges and Cooktops))
by hube222 4/7/2009 9:33:54 AM(UTC)
Timer Control Knob Removal (Washer Repair)
by Abaco 3/12/2008 9:03:27 AM(UTC)
How to replace timer control (Dishwasher Repair)
by wareagle 12/11/2007 8:13:28 AM(UTC)
