2 Pages12>
FIY
#1 Posted : Monday, May 9, 2011 7:45:21 PM(UTC)
FIY
Since a couple of weeks ago, the Auto Dry Regular setting stopped working on my Maytag MDG5000BWW dryer. It ran overnight but still not dry clothes.
I tried to troubleshooting and found:
1. With all kinds of timer setting, the igniter may heats up and turn on the gas lit several times at the beginning, but not stay on longer enough.
2. The timer is working in the TIME DRY/AIR FLUFF setting only but not on AUTO DRY neither REGULAR or WRINKLE FREE FABRICS setting.
Due to the dryer ran overnight, I thought that caused by a bad timer. So I ordered a timer and replaced it today. Unfortunately, the replaced timer didn't fix the issue.
I thought the timer and thermostats are separate control systems. If that caused by bad thermostats, at least the timer should stop the dryer when the time cycle is over. But in AUTO DRY setting, the dryer will keep going, none stop.
Appreciate any suggestion and recommendation.
FIY
#2 Posted : Tuesday, May 10, 2011 7:15:20 AM(UTC)
FIY
jbenjamin
's post of Dryer burner lights but goes out after 10 seconds
jbenjamin
#3 Posted : Tuesday, May 10, 2011 10:13:09 AM(UTC)
jbenjamin
I've seen where the coils for the gas valves go bad. Follow this link and it should be #7 and #8 in the diagram, replace both.
Gas valve replacement parts for MAYTAG MDG5000BWW DRYER- GAS | AppliancePartsPros.com
Joe / APP Team
#4 Posted : Tuesday, May 10, 2011 12:07:50 PM(UTC)
Joe / APP Team
FYI,
You have an "auto Advance" type dryer. in the " Auto Dry" setting the heat does control the voltage to the timer motor causing the timer to advance.
The "cycling" or regulating thermostat has to operate(open and close)properly.
It sounds like you may have a clogged exhaust vent, and will need to check and clean the hole pipe system.(you could also disconnect the exhaust vent from the back of the dryer and run a couple of loads of clothes on the auto dry setting, to check).
You may also have a set of weak gas valve coils on the burner assembly,
Part number: AP3094251
You will want to observe the burner/ignition process and make sure you get a flame(ignition) at the burner. It may take 20 to 30 minutes, or a couple of burner cycles before the coils fail.
Good Luck,
FIY
#5 Posted : Tuesday, May 10, 2011 5:18:25 PM(UTC)
FIY
Thanks for the suggestion! I'll give a try.
FIY
#6 Posted : Tuesday, May 10, 2011 5:20:29 PM(UTC)
FIY
Originally Posted by: Joe / APP Team Go to Quoted Post
FYI,
Good Luck,
Thanks for the quick response! I'll give a try and keep you posted.
Joe / APP Team
#7 Posted : Wednesday, May 11, 2011 5:31:25 AM(UTC)
Joe / APP Team
FIY,
Great, I'm pretty sure you'll find the problem in one of these areas.
Good Luck,
FIY
#8 Posted : Wednesday, May 11, 2011 10:33:51 AM(UTC)
FIY
FIY,
Good Luck,
Thanks Joe,
It should not be "a clogged exhaust vent" issue. It was dirty, but not now. I deeply cleaned it last weekend by unassambled the exhaust system.
Is the Part number: AP3094251 the right parts? I can't find my dryer model MDG5000BWW in its support list.
Regards,
Joe / APP Team
#9 Posted : Wednesday, May 11, 2011 2:17:43 PM(UTC)
Joe / APP Team
Thanks Joe,
Regards,
FIY,
Yes this part, is the correct part. It is a "kit" and consists of both gas valve solenoids(coils) it will work on your machine, it works on all Maytag gas dryers with a "two coil" gas valve.
No problem, and Thanks
FIY
#10 Posted : Sunday, May 15, 2011 5:11:53 PM(UTC)
FIY
FIY,
Joe,
As you said, the problem caused by coils. After I replaced both of them by using parts that you provided parts # and I ordered from AppliancePartsPros.com, the dryer was back to normal. So far we tried 4 heavy loads already.
Thank you and AppliancePartsPros.com so very much!
2 Pages12>
