RobertB
#1 Posted : Tuesday, March 25, 2008 3:41:49 PM(UTC)
RobertB
I have a situation where my washer does not drain. I am guessing a small article of clothing has been stuck in the drain or motor. I have raised the top of the washer but I don't seem to be able to get the front panel off. Should I lay the washing machine down on it's back to remove the front panel of the cabinet or is there another method I should use?:confused:
#2 Posted : Wednesday, March 26, 2008 1:52:57 PM(UTC)
Hi Robert,
In order to provide most accurate advise we need the complete model number of the washer.
RobertB
#3 Posted : Wednesday, March 26, 2008 3:08:15 PM(UTC)
RobertB
Hi Gene..The model number of the washer is a Fridgedaire #FWX223LBS6. Hope this helps. RobertB
RobertB
#4 Posted : Wednesday, March 26, 2008 3:33:52 PM(UTC)
RobertB
The model number for this frigidaire washer is FWX223LBS6. I need help in getting the front panel removed so that I can get access to the pump and drain hose to check for socks or something which has stopped the water from draining. The spin cycle works ok but the water will not drain from the tub.
#5 Posted : Wednesday, March 26, 2008 7:49:18 PM(UTC)
Robert,
Remove the two screws on the bottom of the front panel. Slide the front panel up to release it from the tabs and pull it toward yourself.
RobertB
#6 Posted : Sunday, March 30, 2008 12:25:18 PM(UTC)
RobertB
Gene..thanks for your help. It was really simple to take out the sock which was clogging the drain and your help in telling me about the two screws at the bottom was a great help. Something so simple to do.
#7 Posted : Sunday, March 30, 2008 11:41:39 PM(UTC)
Robert,
I'm glad you were able to fix it.
Guest (5)
washer does not drain (Washer Repair)
by lukasage 8/31/2015 4:42:43 AM(UTC)
Washer does not drain (Washer Repair)
by erichawkinsa 3/30/2014 6:10:08 PM(UTC)
Dishwasher does not drain completely (Dishwasher Repair)
by jlobb2 12/4/2013 2:42:17 AM(UTC)
by jlobb2 12/4/2013 2:40:46 AM(UTC)
Whirlpool dishwasher does not drain (Dishwasher Repair)
by valv00 3/30/2013 5:05:23 PM(UTC)
Whirlpool Washer does not drain (Washer Repair)
by L-Squared 8/13/2012 4:31:44 PM(UTC)
Jenn Air Dishwasher does not drain completely (Dishwasher Repair)
by jjdoc 6/26/2012 11:41:48 AM(UTC)
dish washer does not drain completely (Dishwasher Repair)
by billnheather 5/27/2012 5:33:36 PM(UTC)
Fridgidaire dishwasher does not drain (Dishwasher Repair)
by boblowe 4/25/2012 6:16:26 AM(UTC)
GE GSD500X-72BA Dishwasher does not drain (Dishwasher Repair)
by vitaly 3/2/2012 9:27:07 AM(UTC)
by garygordon 11/22/2011 4:37:44 AM(UTC)
ge dishwasher does not drain (Dishwasher Repair)
by dmtap 5/16/2011 12:16:14 PM(UTC)
Whirlpool Roper Washer does not drain (Washer Repair)
by jjfreeze 4/30/2011 10:14:18 AM(UTC)
Kenmore washer does not drain properly (Washer Repair)
by ren51 3/1/2011 9:59:39 AM(UTC)
Kenmore Washer does not drain or spin (Washer Repair)
by theturtlefactory 2/27/2011 5:21:36 AM(UTC)
