Spokey
#1 Posted : Saturday, February 6, 2010 8:13:44 AM(UTC)
Spokey
Hello. My GLD5800L dishwasher seems to open the soap dispenser about 10 minutes into a typical 30+ minute cycle. The soap does not get fully dissolved. Is this to late, or is that about the right time?
#2 Posted : Saturday, February 6, 2010 11:32:51 AM(UTC)
Replacement parts for gld5800 models | AppliancePartsPros.com
[COLOR="Blue"]Is this to late, or is that about the right time?[/COLOR]
Sounds about right depending on the cycle type.
Units usually fill, do a pre-wash, empty, refill, start the main wash and then open the detergent door.
Could be a number of things:
1. Food bits/junk is clogging some of the wash arm holes.
2. Something impeding the wash pump. Remove the sump cover and check inside the sump for debris or something wrapped around the chopper. Be careful there is often broken glass in the sump. Also note how the inner piece is installed, put it in wrong and the chopper will eat it.
3. Low water level. Most units should fill to just under the heating element.
Often the pump will be noisy with a low fill as it sucks in air. Often this is just a partially clogged inlet screen filter on the water valve.
Jenn Air Dishwasher soap dispenser door wont open (Dishwasher Repair)
by Guest 10/22/2021 5:22:26 AM(UTC)
Whirlpool dishwasher - Replacing soap dispenser door? (Dishwasher Repair)
by NJGuy 5/17/2021 10:55:47 AM(UTC)
GE Cafe Soap Dispenser (Dishwasher Repair)
by Gary Ceepo 6/19/2017 10:04:55 AM(UTC)
Kitchenaid Dishwasher soap dispenser won't open during cycle (Dishwasher Repair)
by dawnbeaufort@gmail.com 12/18/2015 3:22:47 PM(UTC)
inoperable soap dispenser (Dishwasher Repair)
by Luth 10/26/2015 12:17:47 PM(UTC)
kitchenaid dishwasher soap dispenser not opening (Dishwasher Repair)
by tsquilanti 9/16/2015 10:44:29 AM(UTC)
Remove & Install Soap Dispenser (Dishwasher Repair)
by doloresann 1/17/2015 7:55:32 AM(UTC)
water leaking from soap dispenser housing (Washer Repair)
by suekevin 1/8/2015 12:21:56 PM(UTC)
Bosch Soap Dispenser Rattles (Dishwasher Repair)
by Jmccullough 5/28/2014 4:21:11 PM(UTC)
Can someone help me with a Bosch soap dispenser (Dishwasher Repair)
by jonjonbear 3/19/2014 6:50:24 AM(UTC)
Kenmore soap dispenser not opening (Dishwasher Repair)
by Woodworker2001 2/9/2014 7:09:38 AM(UTC)
soap dispenser not opening and short cycle (Dishwasher Repair)
by wkroeplin 12/5/2013 2:48:34 PM(UTC)
maytag soap dispenser won't open (Dishwasher Repair)
by jjleip11 9/15/2013 1:44:50 PM(UTC)
Bosch Dishwasher Soap Dispenser won't ope (Dishwasher Repair)
by jaredw 5/31/2013 3:04:58 PM(UTC)
Maytag Soap Dispenser Not Opening to Dispense Soap (Dishwasher Repair)
by tomball 1/22/2013 6:48:46 PM(UTC)
