tko4081
#1 Posted : Saturday, February 6, 2010 11:02:46 AM(UTC)
tko4081
I change the heat element.It does not dry dishes like it use to it as 120 deg. hot water. clean dishes ok:cool:
#2 Posted : Saturday, February 6, 2010 11:49:36 AM(UTC)
Replacement parts for FRIGIDAIRE FDB1050REB0 Frigidaire/dishwasher | AppliancePartsPros.com
Here is the tech sheet
http://manuals.frigidaire.com/prodinfo_pdf/Kinston/154547901.pdf
When you replaced the heater did you check it or did you just replace it because you felt it was the most likely cause?
Is the vent opening?
tko4081
#3 Posted : Saturday, February 6, 2010 12:48:17 PM(UTC)
tko4081
Originally Posted by: denman Go to Quoted Post
http://manuals.frigidaire.com/p...df/Kinston/154547901.pdf
can not answer that would be next thing to check the vent move up and down
#4 Posted : Saturday, February 6, 2010 12:59:05 PM(UTC)
Yes, perhaps it is not letting the steam out
tko4081
#5 Posted : Saturday, February 6, 2010 1:06:50 PM(UTC)
tko4081
may be the switch is bad
tko4081
#6 Posted : Saturday, February 6, 2010 1:26:18 PM(UTC)
tko4081
:) may be the switch is bad
The dry mode is on know and it still as soap sud
#7 Posted : Saturday, February 6, 2010 1:44:05 PM(UTC)
Sorry but I do not understand
tko4081
#8 Posted : Sunday, February 7, 2010 5:54:14 AM(UTC)
tko4081
The bake element never gets hot or steam from front of door i open the door right before dry cycle element was not hot
#9 Posted : Sunday, February 7, 2010 8:15:31 AM(UTC)
Open it during the dry cycle and see if it is hot.
If not then
Remove check that the hi-limit thermostat is OK, should be 0 ohms.
Check that the heater is OK, should be around 20 ohms.
If both are OK then probably the control board is shot or you have a bad connection between the board and the heater/hi-limit.
Frigidaire dishwasher code A (Dishwasher Repair)
by Evandtam 6/27/2024 5:11:41 PM(UTC)
Fisher Paykel Drawer Dishwasher will not Lock (Dishwasher Repair)
by thompsdw 6/17/2024 7:34:54 AM(UTC)
Dishwasher won't work. (Dishwasher Repair)
by Guest 5/23/2024 6:32:18 PM(UTC)
High-pitched noise with LG dishwasher (Dishwasher Repair)
by Guest 5/17/2024 5:13:53 AM(UTC)
Cafe Dishwasher little to no heat, not cleaning dishes well. (Dishwasher Repair)
by Jtaylor20 5/16/2024 10:15:38 AM(UTC)
Bosch Dishwasher dirty water in filter " hole" (Dishwasher Repair)
by Guest 5/14/2024 9:47:25 AM(UTC)
Bosch dishwasher SHVM78Z53N/01 (Dishwasher Repair)
by Guest 5/8/2024 8:58:29 PM(UTC)
Continuity TEst Samsung p/n 33299012 Dishwasher Water Inlet Valve. (Dishwasher Repair)
by cprodave 4/27/2024 6:55:56 PM(UTC)
Samsung DMT400RHS Dishwasher Over Level Water Error. (Dishwasher Repair)
by cprodave 4/27/2024 6:24:56 PM(UTC)
Samsung Dishwasher Water Inlet Valve--how to Test? (Dishwasher Repair)
by cprodave 4/27/2024 6:18:51 PM(UTC)
Kitchen aid dishwasher bottom leaking (Dishwasher Repair)
by Guest 4/21/2024 10:31:25 AM(UTC)
Bosch Dishwasher SHE3ARF6UC/22 E15 Error (Dishwasher Repair)
by codyace 3/29/2024 11:51:41 AM(UTC)
GE dishwasher GDT695SSJ0SS middle arm not spinning (Dishwasher Repair)
by merrittjr 3/23/2024 10:51:00 AM(UTC)
Bosch Dishwasher Display Goes Out After Latching Door (Dishwasher Repair)
by Guest 3/11/2024 7:00:18 PM(UTC)
Kenmore 90 665 dishwasher noise from impellor (Dishwasher Repair)
by Guest 3/10/2024 12:30:08 PM(UTC)
