svankampen
#1 Posted : Saturday, March 29, 2008 8:57:36 AM(UTC)
svankampen
I'm not sure on the age of this machine. Leaks water sporadically, in the past Iv'e taken it apart and cleaned what looks like a breather on the hose going to the fabric softner dispenser. Haven't done that for a while, and it's been leaking rather regularly lately, so I thought I would take it apart. Well, this time the whole floor underneath is oil covered, looks like it's coming from the gear case. Is this something worth fixing? Do I have to replace the whole gearcase?
#2 Posted : Saturday, March 29, 2008 12:28:12 PM(UTC)
You can try to fix the old gear case. You have to remove it, replace the shaft seal, replace the oil and reseal the cover.
- The part number for the shaft seal is AP2908074
- The part number for the gear case oil is AP3072960
- The part number for the sealer is AP3073576
You can replace the whole gear case assembly.
- The part number for the gear case assembly is AP3096209
svankampen
#3 Posted : Monday, March 31, 2008 4:32:39 PM(UTC)
svankampen
Thanks for the info. I looked up the paperwork and found that the washer was 16 years old. Not that I'm biased against old things; my wife is 3 times that, but I think I'm going to look for a new one. Thanks!!!
Maytag top load washer leaking oil from transmission (Washer Repair)
by Rdchapman2 2/27/2022 1:15:02 PM(UTC)
Maytag Washer MTW5740TQ0 leaking oil (?) from bottom (Washer Repair)
by scotpiper 4/8/2019 7:03:37 AM(UTC)
Whirlpool Leaking Oil and Clothes Still Damp (Washer Repair)
by jeffceo 1/29/2017 5:03:34 PM(UTC)
Washer leaking oil (Washer Repair)
by coldak 11/15/2015 1:27:11 PM(UTC)
Washer leaking oil onto floor (Washer Repair)
by gtg932 9/13/2014 11:02:12 PM(UTC)
Maytag Centennial Washer Leaking Oil (Washer Repair)
by hathawayrepair 2/16/2013 7:12:35 PM(UTC)
Washer Leaking Oil into Drum (Washer Repair)
by Jim Ortiz 2/14/2013 11:45:29 AM(UTC)
Washer does everything but spin, it is leaking oil (Washer Repair)
by regdor 7/26/2011 4:07:55 AM(UTC)
by judbgrdmchn 11/6/2010 2:05:44 PM(UTC)
Leaking oil (Washer Repair)
by gordon_sorensen 6/10/2010 11:52:54 AM(UTC)
Washer leaking oil and water (Washer Repair)
by suefox51 12/5/2009 9:20:02 AM(UTC)
Maytag LAT9605AAE leaking oil and banging (Washer Repair)
by jaywilson 10/25/2009 4:20:08 PM(UTC)
washer leaking oil into washer (Washer Repair)
by swansea1950 9/18/2009 5:39:06 PM(UTC)
kenmore washer leaking oil (Washer Repair)
by scottwalsh 3/25/2009 1:19:36 PM(UTC)
Gearcase leaking oil (Washer Repair)
by leakycauldron 2/7/2009 9:13:02 AM(UTC)
