lucky_me
#1 Posted : Saturday, February 6, 2010 12:57:39 AM(UTC)
lucky_me
I have a GE side by side refrigerator. My refrigerator would not cold down to the default setting, which is 0 for the freezer side and the other 37 degree. Right now, the temperature from the display indicate it is 75 degree both sides. I clean the condenser assembly for any dirt. Any help would be appreciate.
#2 Posted : Saturday, February 6, 2010 3:02:11 AM(UTC)
Most probable failure (if the compressor is not running) is th emotherboard in the back of the fridg. If you are handy at soldering, I would remove the board and check for bad solder joints at the power relay. If ok, order the board, AP4436216
lucky_me
#3 Posted : Saturday, February 6, 2010 10:07:44 AM(UTC)
lucky_me
Is my compressor bad or my motherboard is bad? Once I plug in the refrigerator everything seem to work except the freezer and the fridg side temperature does not goes down, it still stay at 75 both side. How could you test if the compressor is bad or the motherboard?
#4 Posted : Sunday, February 7, 2010 12:02:37 AM(UTC)
Jam the condensing fan blade and plug in the fridg. If the compressor is warm and vibrating, it is running. If the condenser is room temperature, you either have a bad compressor or a clogged capillary. A clogged capillary will cause a low current draw, like well below 1 amp for a 1/5 hp compressor. If in doubt, I would get a pro to look at it.
lucky_me
#5 Posted : Monday, February 8, 2010 10:34:43 PM(UTC)
lucky_me
You are right. The motherboard of the power relay solder is bad. I just solder the connection back. Now, my fridg is working. Thank you for your help richappy.
#6 Posted : Tuesday, February 9, 2010 12:28:23 AM(UTC)
Good work, the power relay area is relatively easy to solder and do a neat job.
