2 Pages<12
popow1
#11 Posted : Tuesday, January 20, 2009 12:22:47 PM(UTC)
popow1
we have a maytag gas dryer and we need to know how to get the front panel off thanks
kayakcrzy
#12 Posted : Tuesday, January 20, 2009 4:07:10 PM(UTC)
kayakcrzy
If you guys have blond hair, you should easily attract men to help. Tom
addison
#13 Posted : Wednesday, January 21, 2009 10:16:51 AM(UTC)
addison
cute :)...I may rather do it myself or hire someone! But thanks for the adivse!
kayakcrzy
#14 Posted : Wednesday, January 21, 2009 4:05:19 PM(UTC)
kayakcrzy
Come on, I know you can do it. Tom ApplianceEducator.com
addison
#15 Posted : Friday, January 23, 2009 5:31:28 PM(UTC)
addison
last night I realized I was the one that brought up the "clip"...I decided to go back to your first response which was "pull and hold on to the tube"...stick w/your first response and forget the clip...2 knuckles and a heat coil later and you were right to begin with...but!!! I see you have responded to someone that they have replaced the coil and still no heat and that unfortunately is my problem...thanks Tom...we'll move on
leedee888
#16 Posted : Tuesday, February 2, 2010 2:01:00 PM(UTC)
leedee888
Originally Posted by: kayakcrzy Go to Quoted Post
Here is the trick. Get a putty knife, and on the top part of the bottom panel, about 5 inches in on the left side is a clip. Push the putty knife inside the clip, and it will release the front on that side. Do the same on the other side. Also when you replace the element, there is a 1/4 inch screw between the two element terminal, that also holds the element in place. When you pull the old element out, hold on to the tube that the elemnt slides into with the other hand. Use a pliers to pull the old one out. It is hard sometimes to pull out. Tom
Can I take this panel off to clean the lint? OR is there no way lint can be behind that panel? I was trying to clean out all the lint where the filter goes and thought I should clean behind that panel but couldn't get it off...your instructions will help but I want to make sure there is a need first, so could there be lint behind that panel? Thx Lee
kayakcrzy
#17 Posted : Wednesday, February 3, 2010 3:21:54 AM(UTC)
kayakcrzy
The only way you can clean the dryer is from the front. The back does not come off. Tom ApplianceEducator.com
dua
#18 Posted : Tuesday, February 7, 2012 10:57:15 AM(UTC)
dua
A picture of the clips and receivers if this helps future users...
dua attached the following image(s):
2 Pages<12
