vsabl
#1 Posted : Wednesday, March 26, 2008 12:48:12 PM(UTC)
vsabl
Hello, when we have a power outage, my control panel on my Thermador double (convection) oven beeps F7 and the oven won't work. We have a power surge on our main circuit box but it doesn't seem to help. We've had the control panel replaced 2-3 times already and it's having problems again after an outage.
Any suggestions?
Thanks in advance.
#2 Posted : Wednesday, March 26, 2008 6:54:27 PM(UTC)
The electronic parts in your oven are very sensitive to improper power source which causing a severe damages.
The error code "F7" means the control panel has to be replaced. In order to provide the right part number for the control panel I need the color of the panel.
Here are the break down diagrams for the Thermador oven Model SCD272T
vsabl
#3 Posted : Thursday, March 27, 2008 5:25:51 AM(UTC)
vsabl
Will check for the color of the panel. Does this mean I'll be replacing the control panel every time there's an outage? Is there any way to avoid this? I already have a surge protector on my main electrical panel.
Thanks again.
paulawitkins
#4 Posted : Thursday, November 6, 2014 8:42:15 PM(UTC)
paulawitkins
I'm sorry about what happened to your oven. I completely understand how inconvenient it is on your part. Using these things signifies that they may eventually bust. NO matter how careful we are with these appliances, we can't deny the fact that this usually happens. When and if they bust, you should think about downgrading your appliances, rather than replacing them. Replacing or upgrading them are not the only options you have when this happens. A good suggestion is to downgrade the appliance you have. It could eventually save us more money. It's good that you have considered looking for other ways to fix the oven rather than replacing it right away. Article resource: Don't replace, downgrade.
Thermador double oven from '99 troubleshoot (Oven Repair (including Ranges and Cooktops))
by mike_balt 5/6/2024 4:16:42 PM(UTC)
thermador double wall oven (Oven Repair (including Ranges and Cooktops))
by Guest 4/8/2024 11:57:14 PM(UTC)
Removing igniter from thermador star (Oven Repair (including Ranges and Cooktops))
by Guest 2/24/2024 9:17:28 AM(UTC)
Thermador SEC301BP Display Dim (Oven Repair (including Ranges and Cooktops))
by tower154 2/11/2024 7:34:06 AM(UTC)
Thermador oven won't start self clean (Oven Repair (including Ranges and Cooktops))
by beb123 2/6/2024 7:34:41 PM(UTC)
Heating issues with Thermador Oven (Oven Repair (including Ranges and Cooktops))
by Guest 1/9/2024 4:34:19 AM(UTC)
Downdraft Thermador exhaust (Oven Repair (including Ranges and Cooktops))
by Guest 12/30/2023 2:38:37 PM(UTC)
Broken Roller Support for Upper Rack - Thermador DWHD770CFP/22 (Dishwasher Repair)
by Smimo4708 12/11/2023 11:28:47 AM(UTC)
Thermador modern internals into retro hood? (Oven Repair (including Ranges and Cooktops))
by Guest 8/27/2023 5:02:55 AM(UTC)
Thermador Range Hood - buttons blinking and fan difficult to control (Oven Repair (including Ranges and Cooktops))
by alanmiller 8/12/2023 9:51:57 AM(UTC)
Thermador Gas oven won't light (Oven Repair (including Ranges and Cooktops))
by Guest 8/1/2023 8:48:27 AM(UTC)
Thermador wall oven temp sensor (Oven Repair (including Ranges and Cooktops))
by dxg2 6/4/2023 11:36:40 AM(UTC)
How to diagnose Thermador gas oven PG366BS not heating? (Oven Repair (including Ranges and Cooktops))
by Guest 4/12/2023 12:28:01 PM(UTC)
Thermador KBUDT4270A02 SxS door gasket (Refrigerator & Freezer Repair)
by metropical 3/17/2023 4:03:27 PM(UTC)
Thermador prg304gh range top removal (Oven Repair (including Ranges and Cooktops))
by Guest 1/5/2023 2:15:44 PM(UTC)
