m donnini
#1 Posted : Sunday, January 31, 2010 12:41:36 PM(UTC)
m donnini
I Have A Kenmore Side By Side Refrigerator That Is Not Cooling On Either Side. Both Fans Working Compessor Running. Deforst Realying Working. I Put 8 12oz Cans Of R134 In Compessor And Still Not Cooling Dont No How Much Of R134a To Put In Compressor Its Not Over Charged Because Compressor Not Making Noise. Need Help.
#2 Posted : Monday, February 1, 2010 1:26:41 AM(UTC)
The model number does not look correct.
Kenmore numbers are usually all numerals XXX.XXXXXX please check it.
[COLOR="Blue"]I Put 8 12oz Cans Of R134 In Compessor And Still Not Cooling Dont No How Much Of R134a To Put In Compressor Its Not Over Charged Because Compressor Not Making Noise.[/COLOR]
If the cans keep emptying into the unit then I would say you have a pretty large leak somewhere, that is a fair amount of freon.
Why did you add freon to start with?
Was there any frost at all on the evaporator coils?
If there was no frost at all then you are out of freon (empty) OR there is a plug in the sealed system OR the compressor is toast.
Just because the compressor does not make any abnormal noises does not mean that the sealed system?compressor is OK.
You cannot just add freon, the only way I know of reliably filling/checking a sealed system is to hook up a set of gauges.
It may be time to get in a pro.
Here is some info that you may find useful
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/3d8fb64d39b18f32852573e900690488/$FILE/8178688%20%28Sealed%20System%29.pdf
m donnini
#3 Posted : Monday, February 1, 2010 9:35:16 AM(UTC)
m donnini
there was no frost on evaporator coils,thats why i added freon to system i checked for visable signs of leaks could not see any or hear any leaks when putting feron in the gauge was reading 80 on high side. could it be the mother board gone bad. i tried to find it but have no idea were it is at.
#4 Posted : Monday, February 1, 2010 12:46:19 PM(UTC)
[COLOR="Blue"]could it be the mother board gone bad. [/COLOR]
I doubt it as most units are either on or off and you said the compressor is running. Some newer units use an inverter and the compressor is always on but at low rpm.
[COLOR="Blue"]i tried to find it but have no idea were it is at.[/COLOR]
I cannot say as I cannot find any info using the given model number.
Refrigerator Compressor Starting With Failed Start Relay??? How Can This Be? (Refrigerator & Freezer Repair)
by AppliancePartsAmateur 7/1/2024 5:18:48 PM(UTC)
GTS16DTNKRWW Refrigerator - Intermittent Operation (Refrigerator & Freezer Repair)
by seocom 6/22/2024 6:51:32 AM(UTC)
GE refrigerator/freezer side by side (Refrigerator & Freezer Repair)
by Pdynamo 6/20/2024 6:20:43 PM(UTC)
Kitchenaid refrigerator and freezer intermittently to warm (Refrigerator & Freezer Repair)
by Guest 6/18/2024 12:12:20 PM(UTC)
Whirpool WRF535SMBM Refrigerator (Refrigerator & Freezer Repair)
by goclones 6/16/2024 8:15:11 AM(UTC)
Samsung Refrigerator Pantry Drawer Support #SAM-DA61-03174A (Refrigerator & Freezer Repair)
by joecoliphant 6/15/2024 8:12:03 AM(UTC)
Ice behind fan pannels in refrigerator and fan not working (Refrigerator & Freezer Repair)
by Mark7604 6/9/2024 6:43:14 AM(UTC)
GTR22HBTARBB water leak to bottom refrigerator (Refrigerator & Freezer Repair)
by wilsonjiaho 6/8/2024 4:24:50 PM(UTC)
LG Refrigerator - Makes ice, but won't dispense ice nor water (Refrigerator & Freezer Repair)
by teamfindley 5/28/2024 7:48:32 PM(UTC)
samsung fd refrigerator (Appliance Repair Companies - East of the Mississip)
by gale reid 5/28/2024 3:17:33 PM(UTC)
Cold-Coldest setting on meat drawer on GE GNE25j refrigerator (Refrigerator & Freezer Repair)
by Guest 5/23/2024 11:20:53 AM(UTC)
Refrigerator freezer (freezer is above refigerator,) (Refrigerator & Freezer Repair)
by cwillman 5/16/2024 12:29:58 PM(UTC)
GE Side by Side Refrigerator Model GSS25IYNXHFS dim LED lights (Refrigerator & Freezer Repair)
by jhauter 5/15/2024 4:30:46 AM(UTC)
Refrigerator Ice (Refrigerator & Freezer Repair)
by Guest 5/9/2024 7:00:37 AM(UTC)
GE refrigerator Ice machine not working. (Refrigerator & Freezer Repair)
by Don718 5/6/2024 11:45:46 AM(UTC)
