flewis46@comcast.net
#1 Posted : Tuesday, March 25, 2008 6:37:19 PM(UTC)
I HAVE A BAD COUPLING. NOT SURE HOW TO REPLACE. DO YOU REMOVE TRANSMISSION? HELP!!!!! MARK:confused:
#2 Posted : Wednesday, March 26, 2008 2:07:38 AM(UTC)
Just remove the outer case of the washer, remove pump, and motor. Pry off the bad coupler and pound on the new one. Turn the tranny coupler clockwise till the spin basket just starts to turn. If hard to turn the coupler with thumb and forefinger, you have other problems. Post results.
Washer Motor Coupling Keeps Failing (Washer Repair)
by hunter02 2/8/2015 12:52:27 PM(UTC)
Whirlpool Direct Drive Washer Motor Coupling (Washer Repair)
by AwakenSatori 7/7/2013 3:44:40 PM(UTC)
