My oven controller/display blacks-out (loses power) when the oven is in operation. When the oven cools the display returns. I have removed the stove top to access the controller , but see no visible signs of damage to the wiring or the circuit board. The controller is not available any more.Was there a problem with this specific model?
THIS FORUM IS DEAD!!!!!!! |
Hello Denman, It took some time to find it, but you were correct.The neutral,feeding the controller,was loose inside the multi-pin connector. I couldn't get a good connection so I soldered the wire straight to the board. Works like new.
Thanks for your help, Midwayyankee
Glad to hear you found it
Thanks for getting back to us, your solution may well help others with this type of problem. |
Midwayyankee or denman, I believe I am having the same exact problem with my Amana oven. I bought a new motor (I was lucky enough to find one and think I might have found the last one!) and new control limiters. I installed them but still had the same issue with oven shutting down. Tested the fan with test cord and it's working. In fact the old fan works even. Now I think I have the same problem midwayyankee did. However, I don't understand which part he's talking about. Could you be more specific about the neutral feeding to the controller?
I sure am glad I found this forum. I don't have the money to buy another oven right now and have hope I won't have to.
