midwayyankee
#1 Posted : Saturday, January 30, 2010 11:47:31 AM(UTC)
midwayyankee
My oven controller/display blacks-out (loses power) when the oven is in operation. When the oven cools the display returns. I have removed the stove top to access the controller , but see no visible signs of damage to the wiring or the circuit board. The controller is not available any more.Was there a problem with this specific model?
#2 Posted : Sunday, January 31, 2010 4:45:28 AM(UTC)
Replacement parts for AMANA ACS3350AS Range - S/c S/i Gas | AppliancePartsPros.com
Here is a tech sheet
http://www.servicematters.com/maytag_library/docs/T231_15R0.pdf
Here is a manual
http://www.servicematters.com/maytag_library/docs/S231_2R1.pdf
And finally a tech bulletin which may apply.
http://www.servicematters.com/maytag_library/docs/TDC-0044A-B.pdf
Looks like there were heat issues but it was probably blowing boards.
Unplug the unit.
Does sound like a bad connection somewhere in the unit, the trick will be finding it.
If the unit has a cooling fan make sure it is working.
Check all connections going to and on the control board.
Check them for tightness, pitting and discoloration.
midwayyankee
#3 Posted : Monday, February 1, 2010 4:12:43 AM(UTC)
midwayyankee
Hello Denman,
It took some time to find it, but you were correct.The neutral,feeding the
controller,was loose inside the multi-pin connector. I couldn't get a good
connection so I soldered the wire straight to the board. Works like new.
Thanks for your help,
Midwayyankee
#4 Posted : Monday, February 1, 2010 4:22:22 AM(UTC)
Glad to hear you found it
Thanks for getting back to us, your solution may well help others with this type of problem.
phooey2000
#5 Posted : Friday, October 21, 2011 6:50:26 PM(UTC)
phooey2000
Midwayyankee or denman, I believe I am having the same exact problem with my Amana oven. I bought a new motor (I was lucky enough to find one and think I might have found the last one!) and new control limiters. I installed them but still had the same issue with oven shutting down. Tested the fan with test cord and it's working. In fact the old fan works even. Now I think I have the same problem midwayyankee did. However, I don't understand which part he's talking about. Could you be more specific about the neutral feeding to the controller?
I sure am glad I found this forum. I don't have the money to buy another oven right now and have hope I won't have to.
