My wife lifted the non-removable top of our maytag. The gas pipes leading to the 2 front burners snapped. I have fixed just about every other appliance and gas and/electrical thing we own from the hvac to the outdoor grill to the jacussi. I have identified the part(s) I need as the Fitting assy., Orifice (lt) Part Number: AP375397. I think I can do this. Can I do this? Any advise? There is less available on line than other diy repairs I have made. Thx
This part is not too difficult to replace yourself and I believe you can do it. The part number you mentioned is for conversion to LP. You have to order the fitting assembly with the part number AP375375. Looks like you'll need two of them. Here are the break down diagrams for the Maytag range Model MGR5710ADWGene.
Thanks Gene. I have noodled out the r and r. It looks stright forward. Thanks for the heads up on the part correction. Yes I need 2. There is no "right hand" I presume. I will order them as soon as you confirm the same part fits both sides. cheers!:D
There is no "right hand" fitting assembly in the parts list.
If the burner knobs on the control panel are (from left to right) left front, left rear, right front and right rear - then both parts are identical.
Dang it! In fact It is set up L-front, L-rear, R-rear R-front respectively. I will need to call and check into the availability of a "right side". Thanks again for the heads up. I'd like to order from this sight given the prices and help I rcvd.
Call the APP customer service (877-477-7278) and ask for Adam.
