rdnyjoh
#1 Posted : Monday, March 24, 2008 5:56:51 PM(UTC)
rdnyjoh
opened front panel and no flame. Igniter not glowing.Checked coils ok.I am guessing maybe I need a igniter?
#2 Posted : Tuesday, March 25, 2008 2:58:51 PM(UTC)
There are five major electrical parts involved in the heating process:
1. High limit thermostat (#17 on the gas valve break down diagram)
2. Cycling thermostat (#8 on the motor break down diagram)
3. Igniter (#4 on the gas valve break down diagram)
4. Flame sensor (#18 on the gas valve break down diagram)
5. Gas valve coils (#7 on the gas valve break down diagram)
How to find out which part causing the problem?
Pretty simple: all of these parts have to be tested for continuity in the above sequence.
The following article on our forum will explain in detail how to run a continuity test using either an analog meter or a digital meter - How To Check Continuity With Ohmmeter
If any of them is open – it has to be replaced.
Gas valve coils also could be tested by resistance. There are two coils – one with three terminals and one with two terminals.
1. Coil with two terminals should have 1220 ± 50 Ohms
2. Coil with three terminals if held with terminals in upper position:
a) across the left and the middle terminals – 1365 ± 25 Ohms
b) across the left and the right terminals – 560 ± 25 Ohms
- The part number for the high limit thermostat is AP275754
- The part number for the cycling thermostat is AP276896
- The part number for the igniter is AP3109449
- The part number for the flame sensor is AP2910747
- The part number for the gas valve coils kit is AP3094251
Here are the break down diagrams for the Maytag dryer Model MDG7057BWQ
rdnyjoh
#3 Posted : Thursday, March 27, 2008 6:51:49 AM(UTC)
rdnyjoh
Thanks Gene. I guess I really did not need to ask this question as you have answered it so many times in this forum.My igniter was cracked.This forum was a great help made changing this part a very simple process. Thanks again.
#4 Posted : Thursday, March 27, 2008 9:01:06 AM(UTC)
I'm glad you were able to fix it.
Maytag Dryer No Heat - Burnt Wire - Causes? (Dryer Repair)
by RobH7 11/11/2012 6:56:49 PM(UTC)
Maytag Dryer No Heat (Dryer Repair)
by bros250 7/1/2012 3:16:45 AM(UTC)
Maytag dryer no heat (Dryer Repair)
by terryleeharvey 2/23/2011 6:23:13 AM(UTC)
Maytag dryer NO HEAT (Dryer Repair)
by vettyfunny 1/24/2010 3:59:26 PM(UTC)
by fireeatr 7/20/2009 6:59:33 PM(UTC)
maytag dryer no heat (Dryer Repair)
by rdnyjoh 3/24/2008 6:12:38 PM(UTC)
