fireeatr
#1 Posted : Monday, July 20, 2009 6:59:33 PM(UTC)
fireeatr
I have been searching this forum and stumbled across a couple of similiar problems. I tried undoing the dryer vent and turning it on but it still doesn't heat. The igniter glows and I have replaced both coils. I hear them click when the igniter glows bright orange but no flame. I am having problems with ohm check on the flame sensor and thermal fuse when I apply the digital MM. it seems to register a lot of different readings.
Thanks,
Deron
magician59
#2 Posted : Monday, July 20, 2009 7:05:41 PM(UTC)
magician59
Check to make sure the gas is on. If it is, replace the radiant (flame) sensor.
fireeatr
#3 Posted : Tuesday, July 21, 2009 7:40:49 PM(UTC)
fireeatr
the main gas line is definitely on.
Maytag Dryer No Heat - Burnt Wire - Causes? (Dryer Repair)
by RobH7 11/11/2012 6:56:49 PM(UTC)
Maytag Dryer No Heat (Dryer Repair)
by bros250 7/1/2012 3:16:45 AM(UTC)
Maytag dryer no heat (Dryer Repair)
by terryleeharvey 2/23/2011 6:23:13 AM(UTC)
Maytag dryer NO HEAT (Dryer Repair)
by vettyfunny 1/24/2010 3:59:26 PM(UTC)
maytag dryer no heat (Dryer Repair)
by rdnyjoh 3/24/2008 6:12:38 PM(UTC)
by rdnyjoh 3/24/2008 5:56:51 PM(UTC)
