cluelessdave
#1 Posted : Friday, January 29, 2010 10:53:29 AM(UTC)
cluelessdave
I have already taken pump out, hose's are not plugged, not sure how to check power source with washer apart, also need to know if pump is supposed to turn freely, it seems to turn and catch like a model airplane motor. I think pump needs to be replaced but want to confirm before ordering
sidfink43
#2 Posted : Saturday, January 30, 2010 11:42:08 AM(UTC)
sidfink43
Hi Dave
If the pump is not turning when the machine is in spin mode it is probably the problem. It should spin freely, and you can check it by determining if you are getting 120v to it in spin mode. If so, replacing it probably fix things.
cluelessdave
#3 Posted : Sunday, January 31, 2010 5:24:23 AM(UTC)
cluelessdave
Originally Posted by: sidfink43 Go to Quoted Post
Hi Dave
Thank you I will order new pump.
Guest (4)
