almah1
#1 Posted : Sunday, March 23, 2008 4:35:11 PM(UTC)
almah1
I have received the ignitor from this site and have a few question on installation
I have removed the oven floor and baffle I can see the burner and ignitor but the wires go down through into the back floor of the oven. can i splice the ignitor here or should i try to locate the other end near the valve
Also does it matter which wire on the new ignitor goes which wire on the old connector that i will splice in
#2 Posted : Monday, March 24, 2008 11:51:01 AM(UTC)
You can definitely splice the igniter from inside of the oven and it does not matter which wire where goes.
almah1
#3 Posted : Tuesday, March 25, 2008 7:27:48 PM(UTC)
almah1
Gene thanks for the quick reply oven is working like new The two screws that attach igniter to burner were frozen on I had to drill out the screws and use new screws there must be a easier way to remove old screws whats your secret?
Also the stove top center burner (grill) does not light I hear no clicking sound i have to use a starter stick to light it all other burners work fine the right front burner s a little slow to start maybe take 15-20 clicks before it starts with a big poof
#4 Posted : Wednesday, March 26, 2008 6:33:02 PM(UTC)
I'm glad you were able to fix the oven.
Most likely the problem with the grill is a bad ignition switch and the right front burner probably needs cleaning. For more accurate advise I need the right model number of the range. The model number you posted is incorrect.
almah1
#5 Posted : Wednesday, March 26, 2008 9:26:19 PM(UTC)
almah1
#6 Posted : Saturday, March 29, 2008 10:25:44 AM(UTC)
The part number for the ignition switch is AP2124410
Looking at the burner you can see a few holes around the top part of the burner and a few vertical holes from the ignition side. It is very important to have all these holes open. You can use any sharp pin (like a toothpick) to unblock them.
Guest (5)
Igniter installation for Tappan Oven (Oven Repair (including Ranges and Cooktops))
by robbi6250 12/27/2007 11:11:04 AM(UTC)
